forum.skoda-club.ru • Просмотр темы - мод для Skoda felicia PERFORMANCE MOD +30% BHP FITS SKODA FA
Сообщение MoonS » Пт, 29 май 2009, 0:37
кто что думает об указанном моде? стоит недорого, но не грохнет ли это окончательно старый движек?
http://cgi.ebay.com/PERFORMANCE-MOD-30- ... .m63.l1177
INCREASE TORQUE & BHP,
REDUCE 0-60MPH TIME,
IMPROVE RESPONSE AND FUEL ECONOMY.
FULLY STREET LEGAL
THESE MOD CHIPS ARE (RESISTORS)
BUT PLEASE DONT JUST BUY ONE FROM AN ELECTRICAL SHOP
ONE, IT WONT WORK
TWO, MAY CAUSE DAMAGE TO ECU!!!!
THIS IS CREATED TO INCREASE YOUR CARS HORSEPOWER AND TORQUE. THIS WILL LEAD TO YOUR ENGINE PERFORMING BETTER THEN EVER!!!
Does it come with instructions?
Yes you will get complete step by step instructions with diagrams for easy install.
What is included in this auction?
You get 1 resistor and all necessary instructions to have this mod completely installed!!
Will this void my warranty?
NO our mod will not void out most warranties. If you have a very strict underwriter on your warranty you can undo the module in less than 5 minutes with no traces. You can even Re-Install it later.
Do I need any special skills or tools?
No special skills are required.
Will this module fit my 4cyl, 6cyl, 8cyl?
The Module will fit all engine sizes and types for this make of vehicle, providing they are fuel injected and not turbo or not diesel.
Will this damage my engine?
Absolutely not. Since the altered signal will always stay within the manufacturer's specifications, there is no way for your engine to be damaged in any way.
What is it.
The mod itself is a small resistor that tells your engine control unit (ECU) that all of the air coming into the engine is cold and therefore dense and packed with oxygen. The ECU then takes this information and tells the injectors to fuel slightly more. This in turn makes for a more powerful detonation in the cylinders and releases the full potential of your engine.
Where does it go? The module simply plugs into the IAT sensor which is situated on the air intake tube at the front of the engine bay. I supply full fitting instructions with detailed pictures, its a doddle to fit and you don’t require any engine knowledge.
Is my car compatible? This mod will work on any petrol injected vehicle built after 1988.
What will it do for me? This mod will allow your engine to release its full potential, your power curve will be smoother with flat spots ironed out, your 0-60 will be quicker so you can get off the line faster and your car will experience an increase in top end speed. Also in some cases depending on how you drive, it will boost your MPG by 5%.
How it works.
The Performance module simply wires into the factory harness of the IAT sensor. The module will work with the sensor to provide a new signal to your vehicles computer, or ECU. The ECU then adjusts your air/fuel and timing advance curves to new performance settings. Our Performance module eliminates costly parts and installation of ECU components (many ECU mods require you to solder and modify the main board), and still safely and legally provides the same end results. There is no risk of damage to the engine or electrical system since the modified sensor signal will always remain within the manufacturer’s recommended specifications. The module works in conjunction with your vehicles ECU and will not affect engine reliability. Installation is very simple. All instructions are included and install should take no longer than 15 minutes. The Performance module can even quickly and easily be removed or re-installed at any time.
This small Mod chip will allow you to boost the power of your cars engine, Nothing else will be effected giving the car a 100% benefit. It’s a small electronic resistor that is of the precise resistance to provide 20 BHP+ more to the vehicle. It is inserted between your Vehicles air intake sensor to compromise for the ECU. The effects will be noticed instantaneously. It is extremely easy to fit, and will only take a few minutes of your time.
If you’re thinking about fuel consumption, well, there’s nothing to worry about; in fact, it’s another good point. The fuel consumption, in most cases, has shown to increase by a few MPG. Giving the car better performance all round
MoonS
Сообщение driveralex » Пт, 29 май 2009, 18:50
Выглядит заманчиво :)
driveralex
Сообщение artemique » Пт, 29 май 2009, 19:00
Видел много раз этот eBay лот. Скажу лишь одно, актуально это лишь для инжекторных движков. Для карбюратора не прокатит.
██████ Škoda Felicia ● Volkswagen Golf Mk4
artemique
Сообщение Demetryus » Вс, 31 май 2009, 13:37
Как бы не оказалась эта штука по своей полезности и сути аналогичной той штуке, которая электронная защита от коррозии...
Знаете, как пласебо - не лечит, но помогает добавить уверенности и положительных эмоций :)
Skoda Felicia Combi 1.6 GLX 1998 г. Пробег 258 тыс. км., из них со мной с 2007 г. 111 тыс. км.
Demetryus
Сообщение Flammable » Вс, 31 май 2009, 22:43
artemique писал(а):Видел много раз этот eBay лот. Скажу лишь одно, актуально это лишь для инжекторных движков. Для карбюратора не прокатит.
Очень жаль =(
Demetryus писал(а): Как бы не оказалась эта штука по своей полезности и сути аналогичной той штуке, которая электронная защита от коррозии...
Я спросил у знающих людей по поводу подобных девайсов... Они сказали что если на машине еще НЕТ корозии, то они её достаточно успешно предупреждают. Это, если можно так выразится, аналог оцинкованного кузова... :oops: :(
Flammable
