forum.skoda-club.ru • Просмотр темы - При разгоне звук как будто сечёт выпускной коллектор
Re: При разгоне звук как будто сечёт выпускной коллектор
Сообщение Filter_ » Вт, 01 сен 2015, 17:25
У меня такая же проблема, был у ОД, бесполезно.
Начал гуглить и вот что выдало, на этот трабл в Европе и Америке есть даже TPI, но не на Шкоды, а на VW, вот собственно описание:
"21 10 01 August 25, 2010 2024061
Rattling Noises From Engine Compartment Area or Exhaust System
Customer may complain of a rattling noise from engine or exhaust are while accelerating from 1800-3000 RPM.
In order to complete proper diagnosis and ensure that the noise is coming from the turbocharger, use the following procedure:
1. Ensure that there is no physical damage internal or external to the turbocharger. If damage is observed, continue diagnosis and repair as necessary. If no damage is observed, proceed to Step 2.
2. Test drive the vehicle to duplicate and familiarise yourself with the noise. Noise can typically be duplicated by driving up a moderate incline, beginning at 35 mph in 4th gear(manual or auto trans) and accelerating through the RPM range of 1800-3000 RPM under moderate to heavy throttle. Obey all local traffic laws.
3. Once you have confirmed and familiarized yourself with the noise, attach a 2 ounce wheel weight to the wastegate actuator rod (figure 1) and take the vehicle for another test drive.
If after attaching the weight to the actuator rod the noise is quieter or has changed pitch, DO NOT replace the turbocharger. Remove the weight, create a VTA ticket in ElsaWeb and contact the Volkswagen Techincal Heplline at 800-678-2389.
If after attaching the weight to the actuator rod the noise has not changed, remove the weight and continue diagnosis and repair as necessary.
Note: Use caution when diagnosing the origin of the noise. Although the noise may be originating from the turbocharger, it can be amplified through resonance to the catalytic converter and be misdiagnosed as a loud converter.
Technical background
Because of exhaust gas pulsations the wastegate flap and actuator rod vibrate at the introduction of boost pressure..................."
Вкратце, нужно установить клипсу на актуатор с номером - 06J145220A, после этого проблема должна уйти.
Тут кто-то уже делал такую операцию, помогло или нет?
На зарубежных форумах только положительные фидбеки.
Filter_
Сообщение Filter_ » Чт, 24 сен 2015, 11:13
Установил клипсу, звук стал появляться периодически. Правильно ли понимаю, что помирает актуатор вестгейта или все не так плохо?
Filter_
