forum.skoda-club.ru • Просмотр темы - Fitting Hertz HSK163 in Octavia 2, help.
Сообщение simichoil » Чт, 02 июн 2011, 15:08
Hi to all fans of Skoda. Sorry for writing in english, but my russian is very bad. I have a question and would really appreciate if someonе can help me.
I have my 3rd Skoda - this time it is Octavia vRS FL - 2.0 TDI.
I have an idea of making a full change of the sound in the car. Unfortunatelly i have a problem with fitting the high tone speaker. I have Hertz HSK 163 component system, and the high tone speaker is 25mm Hertz HT25. I removed the old tweeter, and saw that the hole for fitting is smaller. After one hour of carefull working - i made the hole enough big to fit the new speaker. Here is my ptoblem. The Hertz HT25 tweeter is a little bit deeper in front - and the decorative cover in front of the speaker - but the speaker is making it impossible. It is about 5 mm out - and does not allow to fit the decorative grid cover. I think of cutting a hole in the cover - and to put the speaker through the hole - this will allow to see the beautiful Hertz emblem and cover - but am afraid because i dont know how it looks like.
Here is a photo od the tweeter :
Does anyone have the same problem, and have found a solution? Please help me to solve this problem.
Thank you in advance
BTW you have made one amazing forum and Skoda comunity....thank you for that :beer:
simichoil
Re: Fitting Hertz HSK163 in Octavia 2, help.
Сообщение dadec » Чт, 02 июн 2011, 16:28
Hello.You are welcome foreign guest.My second language badly too.I will write you personal message.
Не хочу позориться своими языковыми познаниями :cry:
dadec
Сообщение Eu-Jinn » Чт, 02 июн 2011, 18:55
ну не писал бы ничего :)))
Напишите автору кто-нить пограмотнее, что задолбается доделывать штатное место для твитера+ резко будет чрезмерно ибо твитеры совсем близко стоят
Пилот TurboJet'a
Eu-Jinn
Сообщение dadec » Чт, 02 июн 2011, 19:00
Eu-Jinn писал(а):ну не писал бы ничего :)))
Совсем плохо написал? Это на тот случай чтобы Л.С. проверил :lol:
dadec
Сообщение simichoil » Чт, 02 июн 2011, 21:28
Hi friends, thank you for the answers. Here are some photos for my work.
The problem is with the decorative cover on photo Nr.3 - I can not put it on place because the speaker is very high, and it touches the cover. I need an idea how to fix this. I think of cutting the decorative cover - and put the speaker in it.
Please help :)
simichoil
Сообщение Eu-Jinn » Пт, 03 июн 2011, 6:55
Надо монтировать не с лицевой, а с тыльной стороны. Приклеить с помощью клея или герметика
Пилот TurboJet'a
Eu-Jinn
Сообщение home_boy » Сб, 04 июн 2011, 8:46
I have had the same problem with Space 1. You need to remove the high tone`s grill. Completely. I advise you to sell HT25 and buy more bigger tweeters to install in side racks.
Больше не шкодю..
home_boy
Вернуться в АвтоЗвук
