forum.skoda-club.ru • Просмотр темы - Владельцам Climatronic (коды)
Сообщение 36RusOcta4x4 » Ср, 16 ноя 2005, 15:25
Незнаю было ли на форуме или нет, нужно кому или нет.
Но найдено следующее.
Press the following Keys at the same time: Fan Down + Cold + Econ. Press Red and Blue to display alternative channels,
После нажатия соответствующей комбинации выскакивает меню диагностики.
Вот какие каналы за что отвечают:
1 interior temperature °C
2 sun intensity retarded * 10 W/m2
3 sun intensity * 10 W/m2
4 external temp retards °C
5 external temp. Bumper °C
6 external temp. Suction port °C
7 blowing out temp. Floor space °C
8 blowing out temp. MAS °C
9 Target Geblaesespg. * 0.1 V
10 Be Geblaesespg. * 0.1 V
11 SOLL_Temp. flap Dig.
12 SOLL_Zental flap Dig.
13 SOLL_Uml./Staul. flap Dig.
14 SOLL_Fussr./Def. flap Dig.
15 engine running time S
16 driving speed km/h
17 START_AP Dig.
18 Uml./Frischluft threshold Dig. to
19 compressor out code see plant
20 PI_STELLMAX Ausbl moving. Dig.
21 INT_STELL Ausbl moving. Dig.
22 Epsilon Ausbl moving. Dig.
23 actual blowing out temp. °C
24 target blowing out being. °C
25 - Last detent temp flap Dig.
26 RMP_Temp. flap Dig.
27 + last detent temp flap Dig.
28 - Last detent central flap Dig.
29 RMP_Zental k. Dig. Dia. g. channel INDICATED SIZE OF DIMENSION 30 + last detent central flap Dig.
31 - Last detent Uml./Staul. flap Dig.
32 RMP_Uml/Staul. flap Dig.
33 + last detent Uml./Staul. flap Dig.
34 - Last detent Fussr./Def. flap Dig. 35
RMP_Fussr./Def. flap Dig.
36 + last detent Fussr./Def. flap Dig.
37 service life min. (255 = no telegram)
38 compressor PWM Dig (0... 200)
39 target evaporator being °C
40 actual evaporator temperature °C
41 i-placing evaporator Dig.
42 Epsilon evaporator Dig.
43 refrigerant pressure without
44 BiLevel/MAS threshold Dig. 45 engine temperature °C
46 actual compressor stream mA
47 target compressor stream mA
48 compressor max. stream mA
49 compressor number of revolutions 100/min
50 radiator exhaust heading for signal %
51 windshield wiper mode 0 = out; 1 = interval; 2 =
52 Fdk correction in Abh. of the windshield wiper - Dig.
53 Geblaesespg. correction in Abh. of the Scheibenw. * 0,1V
54 basic number
55 Volkswagen number
56 HELLA number
57 Test-1
58 Test-2
59 Test-3
60 Test-4 extended diagnostic channels for CAN variants dia. g. channel INDICATED SIZE OF DIMENSION receive data
61 freely
62 clamp 15 bits
63 hot light bit
64 external temp filtered °C
65 climatic disconnection bit 66 engine speed x10 U/min.
67 Dimmung %
68 characteristic diagram cooling bit
69 land variant the 2 = USA/1 = Japan/0 = remainder of transmit data
70 freely
71 Zuheizer (PTC) bit
72 compressor (compressor) bit
73 heating from bit
74 external temp. Wasserkasten not filtered °C
75 compressor load Nm 76 blower load of %
77 radiator exhausts of %
78 customer service errors bit (error memory)
PS думаю модераторы разберуться нужна данная тема или нет :wink:
читаем, думаем, пишем
36RusOcta4x4
Сообщение amplifier » Ср, 16 ноя 2005, 15:49
часть на английском, часть на немецком... хм... :?
amplifier
Re: Владельцам Climatronic (коды)
Сообщение flak » Ср, 16 янв 2008, 14:23
36RusOcta4x4 писал(а):После нажатия соответствующей комбинации выскакивает меню диагностики.
Похоже исключительно нужная штука... в мануале-то ни слова про это.
А ОНО показывает только или можно изменить настройки? например алгоритм распределения потоков в авто режиме?
Кто-нибудь уже пользовался?
flak
Сообщение _DM_ » Ср, 16 янв 2008, 15:16
flak писал(а):А ОНО показывает только или можно изменить настройки?
только смотреть
flak писал(а):Кто-нибудь уже пользовался?
было бы чем пользоваться. я ради прикола скорость вытаскивал (несколько отличается от спидометра ;) ), остальное еще более беспонтовое
Skoda Octavia A4 1.6MPI 2006
Skoda Superb 2FL 1.8TSI 2013
_DM_
Сообщение flak » Ср, 16 янв 2008, 15:57
Жалко
если изменить ничего нельзя тогда и нафиг оно...
flak
Сообщение _DM_ » Ср, 16 янв 2008, 16:04
flak писал(а):Жалко
По идее - только для диагностики климатроника (причем специалистом). В повседневной жизни действительно нафиг (имхо)
_DM_
Сообщение Shurick » Ср, 16 янв 2008, 16:22
flak писал(а):Жалко
Вот, точно! Когда народ приобретает авто с климатроником - тут же начинает задавать вопросы по поводу его функций... А человек постарался, скачал и выложил. Тут же ему в ответ: нафиг оно :twisted:
2 flak: а у Вас машина с климатроником? Или Вы в теме высказались, чтоб сказать хоть что-нибудь? :wink:
ЗЫ. Тему надо либо в ФАК, либо прилепить. Вопросов много помню по поводу этих функций.
Shurick
Сообщение flak » Ср, 16 янв 2008, 16:36
Shurick писал(а):
flak писал(а):Жалко
С климатроником. Если я задаю вопрос, значит это меня действительно интересует.
36RusOcta4x4 спасибо конечно за инфу, жаль что практического применения у нее нет... потому как проблема в автоматическом режиме с перегревом в ногах по зиме имеется...
flak
Сообщение _DM_ » Ср, 16 янв 2008, 16:57
Shurick писал(а):ЗЫ. Тему надо либо в ФАК, либо прилепить. Вопросов много помню по поводу этих функций.
Наверное лучше в ФАК, т.к. обсуждать здесь имхо особо нечего
_DM_
Сообщение Partizan095 » Ср, 16 янв 2008, 17:44
Пользуюсь только 1 и 16 функциями)
FL2 TD4 HSE+
Partizan095
Сообщение Вячеслав_90 » Вс, 08 фев 2009, 20:17
А может кто нибудь знает и сможет подсказать есть ли тут скорость вращение турбины, и\или темпратура турбины. пытался сам перевести переводчик выдает откровенный бред. Двигатель AUM.
Вячеслав_90
Сообщение андрюха36 » Вс, 15 фев 2009, 16:21
Привет всем владельцам туриков!!!
У меня вопрос возник с климатом насчет звука кнопок. На служебной СуперБ в свое время, при нажатии кнопок был звук. Когда купил турик, звука на кнопках нет....У всех так? Или его можно как то включить..выключить????
андрюха36
Сообщение _DM_ » Вс, 15 фев 2009, 16:43
dronchik писал(а):....У всех так?
Ни разу не видел по-другому. У меня точно звука нет. :lol:
_DM_
Сообщение HARD » Вт, 24 фев 2009, 16:15
Вячеслав_90 писал(а):А может кто нибудь знает и сможет подсказать есть ли тут скорость вращение турбины, и\или темпратура турбины. пытался сам перевести переводчик выдает откровенный бред. Двигатель AUM.
ап!
HARD
Сообщение 36RusOcta4x4 » Вт, 24 фев 2009, 16:31
ап!
нет нельзя
на эти вопросы даже ECU не знает ответов
Shurick писал(а):Тут же ему в ответ
да вроде не тут же =) больше 3-х лет прошло =)
36RusOcta4x4
