forum.skoda-club.ru • Просмотр темы - Недокументированные функции платформы A5
Сообщение Dron/9K » Вс, 01 апр 2007, 10:30
позаимствовано в конфе ФВ. хотя, что-то есть и в документации :)
Climatronic self-diagnostics
Press ECON and the UP ARROW button, the one that puts the air near the windscreen vents.Then the left temp display and panel show the channel + subchannel. The large number is the main channel, with the little number top right being the sub channel. The Left temp control twisty bit changes the MAIN channel, the central twisty bit (fan speed) changes the sub channel. Following are what they do, does anyone have this in english?
If you push ECON + rights button near recirculated air. You will show into each screen in the climatronic several interesting values. If you go to channel 19 you will show in the right screen the speed, rpm, motor temp. The are others interesting channels but by the moment there is no info. To go to another channel just move the left temp selector to move to another subchannel just move the right temp selector.
Remote Window Closure / Opening After
Leaving the car, press the 'lock' on the remote, and keep it held down (on)....the windows and sunroof will close (only whilst you hold the remote button) Conversely, pressing the 'unlock' on the remote, and keeping it held down will open the windows (but not sunroof) Release the remote when they are at desired position!
Windscreen Wiper Access
The windscreen wipers are neatly tucked away when not in use for aerodynamics and safety. To clean under them or change the blades is easy! With the ignition key in 'off' position or removed, pull the wiper stalk down momentarily. The wipers will wipe to 12 o'clock position and remain in that position. After completing your task, simply repeat the wiper stalk action and the wipers will 'park' in the usual position.
Fuel Flap Release
The electric fuel flap release is inhibited if traveling at over 5mph (a guess)
Automatic Rear Screen Wipe
With your windscreen wipers activated in any mode, selecting reverse will cause the rear screen wiper to wipe once.
Headlamp Washers
Headlamp washers will only wash if your headlights are switched 'on' - at the first time you wash your windscreen, and then every fifth time your wash your windscreen (resets after ignition switched off)
Zone Climate Control Synchronization
If you hold down the AUTO button for three seconds, it will synchronize the temperature setting on both sides of the car to match that of the drivers side. When ever the driver changes his temp setting it will also change it on the passenger side, until a passenger changes their side.
DSG gearbox (with paddles)
If you're in normal D mode on the gearbox, you can engage manual control by just flipping one of the paddles. You can then go up and down the gears with the paddles. It will automatically slip back into D mode if left alone in the same gear for a while, or when you come to a stop. Another way of changing back to auto is to pull one of the paddles and hold it for about 3 seconds. All of this is done without having to move the gear stick over to the + - setting.
Radio Trick
If you hold down the MENU button whilst on FM or AM, until the radio emits a 'boop' the display will then alter to show a signal meter for the station you are listening to and some other useless bumf.
Single-side parking light
When parking on a very dark street (for example - no street lightings), to prevent some one stupid hitting your car by accident, you can switch on one single side parking light. The single side paring light only lights on one side (either left or right) of front (small light only) and rear small light, the number plate light is not on, to use as less power as possible.
To switch on the "single side parking light": Turn on either left or right indicator, then switch off the engine and lock the car. Once you locked the car, the direction indicator will no longer be flashing, and the "single side parking light" switched on instead.
Sunroof
If you leave your sunroof open and it starts raining it will close.
Speed Warning
set the speed warning:- With the ignition on, go to "SPEED WARNING" on the display, using the end "up/down" buttons on the right hand stalk end. You will see SPEED WARNING over dashes, pressing the reset button, on the bottom of the stalk changes the dashes to a highlighted 20. You can now select the desired speed, using the stalk end "up/down" buttons, in 5mph increments. Press the reset button again to accept it, which removes the highlighting.
While this is set, you will hear a chime every time you pass up through the set speed, with a reminder on the display.
To remove the warning, go to "SPEED WARNING" and press the reset button. this replaces the speed set with dashes.
Clean Air
When using the windscreen washers and whilst reversing, the Climatic air conditioning system automatically switches into recirculate mode to reduce nasty smells entering the cabin. The LED on the recirculate button does NOT illuminate but if you have the fan set to speed 2 or above you can hear it speed up. Recirculation continues for about 15 seconds after you finish using the windscreen washers.
Stop & no go...
Pressing the brake (sufficient to light the brake lights) at the same time as the accelerator causes the ECU to ignore the accelerator input. This demonstrates the Drive by Wire system
Locked
When locking your Mk V, pressing the lock button on the remote twice causes the doors to be locked but does not activate the deadlocks or alarm. This is useful say, if you want to lock someone inside the car. The key indicator on the interior central locking button will glow orange to indicate that the deadlocks are not engaged and the red LED on the driver's door will not flash indicating that the alarm is not engaged
Dron/9K
Сообщение TallioN » Вс, 01 апр 2007, 18:13
Спасибо, как машина придет - обязательно изучу подробней
Но мне больше понравилось на сайте известного нам обоим англичанина инструкция по доработке Шкодовского климата до ФВшного. Отличие - у последнего есть кнопка OFF. Чтобы получить ее у Шкоды, надо вытащить среднюю верхнюю кнопку и отломитьь у нее кусочек пластика :D
вот ссыль на описание http://www.octavia-vrs.com/technical/cl ... button.htm
и фотки для сравнения:
TallioN
Сообщение AMP » Вс, 01 апр 2007, 19:36
Уточню - речь идет про отключение компрессора [кондиционера] при сохранении работы вентилятора обдува.
AMP
Сообщение SergDN » Вс, 01 апр 2007, 21:50
AMP писал(а):Уточню - речь идет про отключение компрессора [кондиционера] при сохранении работы вентилятора обдува.
а ЕСОН тогда не проще нажать? или на фольце решили задублировать кнопку? вообще полное отключение климата более логично повесить на кнопку OFF
SergDN
Сообщение Бобёр » Пн, 02 апр 2007, 22:10
Немного не понял, какие примушества дает эта "махинация", как ей потом пользоваться и чем OFF от ECON отличаеться в принципе. Разясните "бестолковому". Заранее спасибо.
Бобёр
Сообщение TallioN » Ср, 11 апр 2007, 8:40
Вот еще в тему http://www.swankmonkey.com/vw/jetta/2006/ecu_recode/
Using the remote to roll up and down the power windows!
Disabling the DRL's (Daytime Running Lights)
Disabling the seat belt chime
Modify alarm honk/flash when arming or disarming
Active Fog Light use with Highbeams
Activate the cabin heater (heat with a cold engine)
Adjust power steering assist (helps with straight freeway dead zone)
Adjust MFA display for instant and average MPG calculation
TallioN
Сообщение SergDN » Ср, 11 апр 2007, 8:59
не очень понятны ряд возможностей...
это описано в инструкции
в инструкции, есть только при заказе coming home
сомнительная опция
в инструкции
а это что?
а это что?
а это что?
да он вроде и так показывает...
SergDN
Сообщение TallioN » Пн, 16 апр 2007, 7:39
Еще (может повтор с изложенным выше, тогда простите)
Some of this is well known, a lot is in the manual, but it is always asked so to save threads post any useful tips and tricks here.
This thread will be trimmed from time to time, with useful info added to the first post.
When you lock/unlock the car, keep the button pressed on the fob and the window will raise/lower. take finger off button to stop
To get to the wiperblades, after having the ignition on, turn the ignition into the off position and pull down the wiper stalk. The wiper arms will move and stay in the full sweep position for you to clean/change the wipers. Putting the ignition back on and pushing the wiper switch down again sends the wipers back into their park position
With the windscreen wipers on, selecting reverse will cause the rear screen wiper to wipe once.
Headlamp Washers (if fitted)
Headlamp washers only work with the lights on, and performs it's action the firstime you clean the windscreen and then every 5th time the windscreen is cleaned. Turning off the headlamps or ignition resets the counter.
Duel Zone Climattronic Synchronization
After a passenger has played around with their temperature settings, press the AUTO button for 3 seconds to re-sychronise
Coming Home Lights
The headlights only stay on for the 30seconds or so if you have put just taken the key out of the ignition. If you dont want them to stay on when youve parked up then lock the car, unlock and lock again.
(Save that oh too familiar "you've left your lights on mate!")
Duel zone climatronc switching between Celcius and Farenheit
Pressing and holding the Auto and Econ Buttons at the same time will swap the temperature from oC to oF and back again (can also be done on in trhe temperature settings if you have Maxidot.
maxidot
The MFD lights up when you open a door but will go out after about 30 seconds unless you do something. Just press briefly the trip button and the display will light back up.
Three blink indicator
IF you have maxi dot, this can be turned on and off in the options screen under ‘comfort coding’
Duel zone Climatronic settings
Like the previous version there are a ton of settings and information hidden in the climatronic computer.
To get this, press the ECON and the top right air direction button (next to recirc) simultaneously. To get back to temperature control press AUTO and ECON simultaneously
The passenger side temp control dial sets the section (1-30)
The fan speed dial sets the subsection and is shown in the passenger side LCD screen to the right of the main number.
The one that everyone wants is true speed, whis can be found in section 19.
Subsection 0 shows Kmh, subsection 1 shows Mph.
Subsection 3 shows the revs to the nearest 100 (tickover is about 870rpm and shows up as 08 on the display)
A little radio trick
If you hold down the MENU button whilst on FM or AM, until the radio emits a 'beep' the display will then alter to show a signal meter for the station you are listening to and some other useless stuff.
Auto shut off light
IF you forget to turn the lights off when you get out and lock the car, don't worry as the lights will turn themselves off after about 1 minute of the door being locked.
VIN numbers
Hold the info button on the radio and a list of VIN numbers come up.
Climate control recirc
When the car is put into reverse gear, the climnate control goes into recirculation mode to prevent fumes from getting into the cabin.
Low oil light
If you get a low oil level warning and then top up the oil but not by a sufficient amount, the low oil level warning light will go out anyway and stay off for 100 miles before coming on again.
Disabling of motion sensors for leaving window open
there are 2 ways
1) If you are by the car, there is a button in by the 'b' pillar on the drivers side, press that before locking
2) Press lock on the remote twice. This will also disables the deadlocks.
__________________
TallioN
Сообщение jurkv » Ср, 02 июл 2008, 12:33
А в статье написано, что эта кнопка на Фольксвагене отключает и кондей, и вентилятор. На Октавии, насколько я знаю, для этого достаточно выкрутить регулятор вентилятора полностью влево, а потом еще раз влево, пока на индикаторах температуры не загорятся слова OFF.
jurkv
Сообщение KGB » Вт, 05 авг 2008, 21:52
Хм. Сделал кнопку отключения - удобно
KGB
Сообщение sh@m@n » Вт, 05 авг 2008, 22:57
Как то при посещении сервиса,непомню по какой причине,данную функцию мне подключил мастер(в подарок) Эта кнопка имитирует убавление оборотов с последующим отключением всей системы,так вот не надо ничего крутить а просто нажал и все.Хотя пользуюсь данной функцией очень редко.
Skoda Octavia Combi А7, 1.8 TSI 4*4
sh@m@n
Сообщение Burbot » Вс, 10 авг 2008, 11:45
KGB писал(а):Хм. Сделал кнопку отключения - удобно
KGB, а кнопочка вытаскивается простым "поддеванием" ножичком, или есть какие-либо тонкости?...
Где карта, Билли? /// Škoda football team, #2
Burbot
Сообщение KGB » Вс, 10 авг 2008, 23:25
Burbot писал(а):KGB, а кнопочка вытаскивается простым "поддеванием" ножичком, или есть какие-либо тонкости?...
Использовал пластиковую карту, как рекомендовванно по ссылке, ножом можно поцарапать.
To remove the button simply lever out the centre with something suitably thin and that won't damage the plastic such as a credit card.
Саму ручку чуть вверх, чтоб щель появилась, просунул карту и кнопочка легко вылезла.
KGB
Сообщение lazan » Пн, 23 мар 2009, 14:02
А может кто-нибудь здесь выложить все фишки, которые можно активировать VAS' ом на машинке без максидота.
lazan
Сообщение Geetler » Пн, 23 мар 2009, 14:21
lazan писал(а):А может кто-нибудь здесь выложить все фишки, которые можно активировать VAS' ом на машинке без максидота.
Это нереально.......
Можешь взять распечатку после диагностики.
В ней будут номера продиагностированных блоков...например блок центр.электроники...по нему находим *lbl файл ваг-кома
3C0-937-049-30-H.lbl
смотрим кодирование/адаптация и длинное кодирование, вот кусок длинного кодирования:
; long coding
LC,00,0,Front Fog Lights installed
LC,00,1,Xenon Headlights with Shutter installed
LC,00,2,Footwell Lights installed
LC,00,3,Daytime Running Lights (Scandinavia) active
LC,00,4,Daytime Running Lights (North America)
LC,00,5,Assistance Driving Light & Leaving Home active
LC,00,6,Rain-/Light sensor installed
LC,00,7,Coming-Home active
LC,01,0,Rear Seat Recognition installed
LC,01,1,Headlight Washer installed
LC,01,2,Electronic Fuelpump Relay installed (Gasoline only)
LC,01,3,Rear Wiper installed
LC,01,7,Rear Wiper with Front Wiper continiously active
LC,02,0,Rear Wiper with Front Wiper intermittent active
LC,02,1,Comfort Turn Signals
LC,02,2,Cold Lamp Diagnosis active
LC,02,3,Load Management active
LC,02,4,Coming-Home Mode via (0 = Personalisation / 1 = Lightsensor)
LC,02,6,Side Turn Signal Lights installed
LC,02,7,Seat Heating installed
LC,03,0,Relay Terminal 15 installed
LC,03,1,Rear Fog Lights (0 = 2 Rear Fog Lights / 1 = 1 Rear Fog Light)
LC,03,2,Reverse Driving Lights (0 = 2 Reverse Driving Lights / 1 = 1 Reverse Driving Light)
LC,03,3,Reverse Driving Light off when Rear Lid open
LC,03,4,Xenon Headlights without Shutter installed (Bi-Xenon)
LC,03,5,Teardrop Wiping for Rear Window active
LC,03,6,2nd Battery installed
LC,04,0,Auxiliary Heater installed
LC,04,4,Activation of both Rear Fog Lights
LC,04,6,Rear Fog Lights deactivated
LC,04,7,Warp Relay installed
LC,05,0-7,50,Headlight Washer Delay
LC,05,0-7,50,Decimal Value (Resolution 50 ms) (Example: 20 is 20 x 50 = 1000 ms)
LC,06,0-7,50,Headlight Washer Activation Time
LC,06,0-7,50,Decimal Value (Resolution 50 ms) (Example: 16 is 16 x 50 = 800 ms)
LC,07,0-7,1,Turn Signal Front left/right as Parking Light Front left/right (USA and Canada)
LC,07,0-7,1,Decimal Value (Resolution: 1%)
LC,08,0,Seat Heating Deactivation with Transport Mode active
LC,08,1,Daytime Running Light (DRL) Deactivation with Transport Mode active
LC,08,2,Footwell Lighting Deactivation with Transport Mode active
LC,08,3,Interlock Display via CAN-Instruments active
LC,08,4,Interior Light via Rear Lid Notch active
LC,08,6,Rear Fog Light Deactivation with Trailer active
LC,08,7,Daytime Running Light (DRL) Deactivation while Blinking active
LC,09,0-7,1,Rear Brake Light as Parking Light
LC,09,0-7,1,Decimal Value (Resolution: 1%)
LC,10,0-7,1,Rear Fog Light as Parking Light
LC,10,0-7,1,Decimal Value (Resolution: 1%)
LC,11,0-7,1,Front Parking Light Dimming
LC,11,0-7,1,Decimal Value (Resolution: 1%)
LC,12,0-7,1,Rear Parking Light Dimming
LC,12,0-7,1,Decimal Value (Resolution: 1%)
LC,13,0-7,1,Backup Function: Rear Side Turn Signal as Parking/Brake Light
LC,13,0-7,1,Decimal Value (Resolution: 1%)
LC,14,0-7,1,Backup Function: Front Parking Light as Side Turn Signals
LC,14,0-7,1,Decimal Value (Resolution: 1%)
LC,15,0-7,1,Backup Function: Rear Parking Light as Side Turn Signals
LC,15,0-7,1,Decimal Value (Resolution: 1%)
LC,16,0-7,1,Backup Function: Front Fog Lights as Low Beam Headlight
LC,16,0-7,1,Decimal Value (Resolution: 1%)
LC,17,0,Emergency Brake Flash Light active
LC,17,1,Deactivation of Additional High Beam with Bi-Xenon
LC,17,2,Heated Front Window installed
LC,17,3,Diagnosis Terminal 50 active
LC,17,4,Daytime Running Light via Fog Lights
LC,17,5,Front Fog Lights deactivated with High Beam
LC,17,6,Parking Light Function inactive (USA/Canada)
LC,18,0,Cold Diagnosis License Plate Lights active
LC,18,1,Cold Diagnosis Brake Lights active
LC,18,2,Cold Diagnosis Front Fog Lights active
LC,18,3,Cold Diagnosis Rear Fog Lights active
LC,18,4,Cold Diagnosis High Beam active
LC,18,5,Cold Diagnosis Turn Signals active
LC,18,6,Cold Diagnosis Back-Up Light active
LC,18,7,Cold Diagnosis Side Turn Signals active
LC,19,0,Cold Diagnosis Low Beam active
LC,19,1,Cold Diagnosis Front Parking Lights active
LC,19,2,Cold Diagnosis Rear Parking Lights active
LC,19,3,Diagnosis Rear Parking Lights active
LC,19,6,Electric Parking Brake installed
LC,20,0-7,1,Daytime Running Lights Dimming
LC,20,0-7,1,Decimal Value (Resolution: 1%)
LC,21,4,Rear Fog Light as Brake Light
LC,21,6,Leaving-Home Variant (0 = LH in LDS / 1 = No LH in LDS)
LC,21,7,Low Beam always active
LC,22,0,Personalization (0 = Variant 1 / 1 = Variant 2)
LC,22,2,Brake Light Deactivation with Rear Fog Light active
LC,22,3,Rear/Brake Light Function active
LC,22,4,Speed dependant Trunk Locking active
LC,22,5,"Light && Sight" Menu inactive
LC,22,6,Rear Parking Lights as Blinker active (North America)
LC,22,7,Diagnosis Rear Brake Lights inactive (North America)
LC,23,0,Xenon Headlights repeated Ignition active
LC,23,1,CAN Data Exchange Format active
LC,23,2,Internal Turn Light Control Algorithm active
LC,23,3~4,00,Turn Lights not active
LC,23,3~4,08,Turn Lights via Fog Lights
LC,23,3~4,10,Turn Lights via High Beam
LC,23,3~4,18,Turn Lights via Xenon Shutter
LC,23,5,Coming-Home Logic (0 = Old / 1 = New)
LC,23,7,Engine Compartment Light via Right Side Blinker Output active
так что никто не будет выкладывать или делиться "всеми настройками"
Geetler
